What do I do??
Old Apr 18, 2006 | 09:29 AM
russ00001's Avatar
Default What do I do??
I just changed the battery in my '95 and my cd changer no longer works!! After I connected the battery I put the correct radio code in and the radio worked. The weird thing is that I cant even select CD on the radio!! It goes through the radio bands but not the CD. Any ideas? Thanks in advance for any help. The members here have helped me out alot!
Old Apr 18, 2006 | 05:41 PM
Landzu's Avatar
Default RE: What do I do??
Eject the CD's holder and reinstall it with the radio on.
You should hear the CD changer sorting the CD's
after that it should work.
Old Apr 18, 2006 | 06:35 PM
russ00001's Avatar
Thanks....I will give it a try and post the results!!
Old Apr 19, 2006 | 09:15 PM
russ00001's Avatar
well after everything, it turned out to be a loose gound!!
Old Apr 20, 2006 | 09:47 AM
Landzu's Avatar
Well at least you found the problem.
Like this sometimes unrelated things happen and
they are the hardest to find.
