What Gear Oil should I buy?
After doing my homework on gear oils for many different rigs (motorhomes, half ton Fords, Rovers)....I came up with the conclusion that dino 85-140w is a very popular weight to run in most gear oil applications. That's what I use.
OK after hearing all the good things about the 85w 140, I filled up the transfer case with it and it shifts like butter lol. However I wanted to go with something closer to what the manual recommends for the differentials so I choose the 80w 90 for the front and rear differentials.
Was this a good choice? Thanks
Your fine. I just believe in the KISS method. I would have used the same oil for all 3 diffs...But at least you serviced them, time to move on to the next project!
I buy it in 5 gal pails and have a pump on the pail to pump it in.
Oh nice thats the way to do it. Thanks for your help and advice to all of you on this forum. I wouldn't have been able to do this service without you guys. Thanks.
The cheapest synthetic that meets the spec, I use Fuchs 75/90 for general road going use but if offroading a lot you could use thicker 80/140, it makes little difference especially to performance or noise.
archaeology_student
Jul 23, 2014 08:43 AM
