What Kind Of Spark Plugs Should I Get?
What kind of spark plugs should I get for my 2000 4.0l? Doing some maintenance and some touch ups to it today and figured these needs to be replaced as well.
I've had awesome success with these E3 spark plugs. Can't say enough good things about them.
http://www.e3sparkplugs.com/
ORIGINAL: Suede
How long have you been using the E3s and what wires are you using?
Thanks!
I've got 22,000 miles on them so far, with Vitek wires. The wires are a bit overkill, as I know from prior use on my Volvo - Magnecor's are a great wire, and about $50 cheaper. But I was upgrading to a MSD ignition, and wanted every bit of electro magnetic insulation I could muster. For those trying to squeeze every last mpg out of their Disco, I highly reccommend considering adding a basic multi-spark ignition module. My disco purrs on the MSD/Vitek/E3 setup...
I too am running the E3 spark plug, both in my Rover and the wifes Volvo.
And Kingsbourne plug wires in both as well.
www.kingsbornewires.com
ORIGINAL: Street Wolf
Champion Platinum's it is then, installed.
Magnacor wires and Bosch +4 Plugs...
marsyas
Feb 25, 2021 08:11 AM
OffroadFrance
Off Topic
Jan 14, 2015 04:56 PM
