What Kind Of Spark Plugs Should I Get?
Old Feb 4, 2009 | 02:57 PM
Street Wolf's Avatar
Default What Kind Of Spark Plugs Should I Get?
What kind of spark plugs should I get for my 2000 4.0l? Doing some maintenance and some touch ups to it today and figured these needs to be replaced as well.
Old Feb 4, 2009 | 03:03 PM
brooksa's Avatar
Default RE: What Kind Of Spark Plugs Should I Get?
This depends on who you ask...I went with the Bosch Plat 4's, haven'thad any problems seems to run perfect.
Old Feb 4, 2009 | 03:27 PM
tomfraser's Avatar
disco mike says +4s
I use them and they work great... but can't compare them to anything as I was previously running plugs that were probably 100k miles old
Old Feb 4, 2009 | 03:48 PM
NiteTrain's Avatar
my vote is for NGK iridiums
Old Feb 4, 2009 | 03:57 PM
Suede's Avatar
I've had awesome success with these E3 spark plugs. Can't say enough good things about them.
http://www.e3sparkplugs.com/
Old Feb 4, 2009 | 04:30 PM
mwindth's Avatar
ORIGINAL: Suede
Suede,
How long have you been using the E3s and what wires are you using?
Thanks!
Old Feb 4, 2009 | 05:11 PM
Champion Platinum's it is then, installed.
Old Feb 4, 2009 | 05:41 PM
Suede's Avatar
I've got 22,000 miles on them so far, with Vitek wires. The wires are a bit overkill, as I know from prior use on my Volvo - Magnecor's are a great wire, and about $50 cheaper. But I was upgrading to a MSD ignition, and wanted every bit of electro magnetic insulation I could muster. For those trying to squeeze every last mpg out of their Disco, I highly reccommend considering adding a basic multi-spark ignition module. My disco purrs on the MSD/Vitek/E3 setup...
Old Feb 4, 2009 | 07:41 PM
I too am running the E3 spark plug, both in my Rover and the wifes Volvo.
And Kingsbourne plug wires in both as well.
www.kingsbornewires.com
Old Feb 5, 2009 | 09:14 AM
okdiscoguy's Avatar
ORIGINAL: Street Wolf
Who said Champion Platinums? I ran them with Bosch wires and they didn't last for anything. Fouled out in 3 months.
Magnacor wires and Bosch +4 Plugs...
OffroadFrance
Off Topic
Jan 14, 2015 04:56 PM
Hurricane Moon
Aug 15, 2010 06:09 PM
elboy0712
Mar 5, 2010 09:01 AM
2002DiscoII
Jan 13, 2006 12:29 PM
