What light is this on my inst. panel
Old 09-26-2013 | 06:48 PM
dusty1's Avatar
Default What light is this on my inst. panel
Away from my computer / rave till Monday. So relying on the google and u fine folks fo some help.
1.5 hr drive today and I noticed a temp. Lookin light on the panel. Top right area had a red thermometer .
Is that to indicate water temp, trans temp ? Or....? Evil robot
My scan gauge has never been above 193.
So.... Help me please. Before my ride melts into the earth.
Old 09-26-2013 | 06:52 PM
TRIARII's Avatar
Vague description but start with this: Discovery series 2 dash lights
Old 09-26-2013 | 07:06 PM
dusty1's Avatar
Thanks T, It is in upper right cluster, the thermometer with waves.
TRIARII's Avatar
That would be your transmission temp. Stop driving, check trans fluid level, check for leaks, check for dirty contaminates in the fluid. When was the last time the trans fluid was flushed?
Heres a link to the owners manual as provided by LR: TOPIx - TOPIx
Old 09-26-2013 | 07:10 PM
dusty1's Avatar
Thanks,That is what I thought. Flushed changed fluid and filter less than 8k ago. No leaks....
Old 09-26-2013 | 07:14 PM
TRIARII's Avatar
I take that back. You said it has waves so it might be the light indicating water in the fuel filter. See below for a complete listing of all the D2 warning lights. Had to do some research to find it...
http://img121.imageshack.us/img121/4379/bordd2.png
Old 09-26-2013 | 07:15 PM
ukwildcats's Avatar
Hot Transmission / Transfer Case Fluid (if this is what is illuminated) could be due to the electric fan for the air conditioner was not working -- extra heat from AC Condenser and the lack of extra cooling from the fan resulted is the transmission fluid being a little hot.
I would check to make sure Electric Fan is operational.
-- see if the fan blade will rotate with a screwdriver
-- or turn on the AC while the engine is on, the electric fan should always be on when AC is operational.
UK
Old 09-26-2013 | 07:24 PM
dusty1's Avatar
All fans good. Steady stream of dex3 ATF flowing. If anything, I have too much fluid. Could that cause a heating issue? Clean and clear fluid a no e brake problems
Old 09-26-2013 | 07:51 PM
coors's Avatar
I don't think you could have too much ATF. Unless, you raised the front of the truck and forced it in there.
Any debris lodged in the grill area causing air flow restrictions or blockage across the trans cooler ?
I scooped up a bat one night. Batman didn't fight anymore crime that night.
How's it shifting and driving? Do you notice any difference in. Shift patterns?
Old 09-26-2013 | 07:53 PM
TRIARII's Avatar
Did you confirm the warning light? Your description was kinda vague. The transmission temp light is a red circular gear with an exclamation mark in it, no waves as you described. There is a orange light with tiny waves and a arch over it. Then there is a orange swirl light. Please verify the specific warning light here and let us know so we can best help you. Dnnt want to give wrong info so we need to make sure we are talking about the same warning light.
Quick Reply: What light is this on my inst. panel
