What is OBD P1187
Old Dec 22, 2007 | 04:26 PM
topel98's Avatar
Default What is OBD P1187
I changed all 4 O2 sensors and I now have a diag of P1187? Any ideas
Old Dec 22, 2007 | 05:16 PM
okdiscoguy's Avatar
Default RE: What is OBD P1187
P1187
Land Rover
HO2S Heater Short Circuit, Upstream Sensors
Where did you get your sensors?
Old Dec 22, 2007 | 05:36 PM
topel98's Avatar
from sparkplugs.com at $70 a piece
Old Dec 22, 2007 | 05:44 PM
So, you have a bad 02 sensor, what brand did you instal, have you rechecked the connection?
I would suggest you call the supplier and see how he wants to handle the warranty replacement.
Old Dec 22, 2007 | 09:38 PM
topel98's Avatar
OK........so how do I know which one it is?
Old Dec 22, 2007 | 10:13 PM
okdiscoguy's Avatar
One of the one's in front of the cats.
Did you wire these in yourself or did they have connectors on them?
Old Dec 23, 2007 | 08:36 AM
So answer my question, where did you buy them and what brand are they??????????????????
Old Dec 23, 2007 | 02:02 PM
topel98's Avatar
I stated above that I bought them on line at sparkplugs.com................
I bought 4 NGK OE identical sensors. They came with connectors on them which just snapped on.............
Old Dec 23, 2007 | 03:41 PM
okdiscoguy's Avatar
Double check all of you connectors to make sure they are mated right. If they are good, one of them is bad. Your sensors have pre-heaters in them and one is not working...
Old Dec 23, 2007 | 04:37 PM
topel98's Avatar
Could we have an electrical problem that is causing this. The guy before me had similar problems and apparently replaced sensors before and couldn't get OBD to clear. I will check to make sure connections are mated up correctly but I did already check to see if they were connected and they were tight.
