What should AC compressor coil ohm out at?
After spending 7 weeks wrestling with a D2 ('04, 190K miles, total rebuild at 128K miles because of a slipped sleeve) that would start but then stall/die (after replacing a half-dozen parts, turned out to be a vacuum leak at the EVAP purge valve-to-intake manifold connector), now that it is running again, I have an AC clutch that doesn't appear to be working.
Here are the symptoms/observations:
I will put the ohmmeter on the clutch coil it today.
What should it ohm out at?
- With the engine running at idle and AC off, the AC compressor clutch plate is static, i.e. not moving at all
- With engine running at idle and AC on, the AC compressor clutch plate is barely engaging, i.e. it is moving but just barely -- maybe one revolution every second or two -- and certainly not at the same speed/rate as the compressor pulley itself.
- With the engine off and jumpering the AC compressor at the relay socket, there no no distinct "click" indicating that the clutch coil has energized and pulled the clutch plate onto the pulley
- Same situation when 12v is applied directly to the compressor clutch coil connector, i.e., no distinct "click" that the clutch plate has engaged with the pulley.
Thanks. I'll keep an eye out for your reading.
Mine tested out at 4.1-4.2 ohms (the base continuity resistance of the probes when touched together on my multimeter is 0.2 ohms).
Also, checked the harness connector with the AC on, and there was 13.5V on the connector so I assume it is not an electrical issue from relay-to-coil.
Finally, after not "clicking" when either jumpered at the relay socket or with 12V applied directly to the compressor coil (using a 60W 12V power supply, so only 5 amps of current), and further after several cycles of not engaging with the AC on and the engine running, the clutch is now engaging sporadically (beyond the normal on-off cycle) and on such one engagement, the clutch kind of howled before fully engaging and settling down.
So still trying to figure out whether I have a weak coil (the ohm reading of a known good coil would help) or maybe a worn compressor clutch plate.
If it's not a weak/failing coil but rather a worn clutch (based on comparing to the ohm reading of a known good coil), could I take the clutch off and remove one of the spacers to reduce the clutch-to-pulley spacing to effectively get more life out of it?
Usually on the Denso AC Compressor the actual clutch surface over time cracks and just eventually can no longer engage. I haven't seen the electrical side actually fail in my personal experience yet. All the units I've seen had pieces missing from the clutch plate itself or it was very rusty and it slipped and caused the rubber ring to melt and render the AC Clutch useless.
