What are the signs of a drive shaft going bad?
Old Jan 25, 2010 | 07:20 PM
fishhawk's Avatar
Default What are the signs of a drive shaft going bad?
Got a 03 discovery and I am getting a slight buzz vibration when I let off on the gas, only when I float the engine and put no bind on shafts. The vibration feels like the outside edge of the tread grooves on a tire hitting the road. Like snow tire at a high rate of speed. no noise just light feel vibration/ buzzing in the steering wheel and gas pedal. I have 107K on it. All the services have been done over the years. I do most of my work, but this one has got me stumped. I first noticed it going down a hill and thought it was grooves in the road. I am noticing it more now because I am picking up on it. Any thoughts before I go spending money. What would the beginning of a joint failure normally start with. Thanks FH
Old Jan 25, 2010 | 07:26 PM
hilltoppersx's Avatar
if it has not been replaced or repaired already, i dont think you should wait any longer.... you should be able to hear the u joints failing even at slow speeds when you first start from stop it will squeal or squeak. vibrations at higher speeds are another sign... whether the shaft is your problem or not you need to fix it ASAP before it causes a heap of damage under your rig.
Old Jan 25, 2010 | 08:04 PM
kallgrer's Avatar
That sounds like a driveshaft going bad to me. The vibration is usual most noticeable under a no load situation like the one you are describing.
Old Jan 26, 2010 | 09:45 AM
Crawl under the truck and count the number of grease fitting on the front drive shaft, if you only have 1, get it rebuilt or replaced ASAP. If you have 3 grease fittings, it has been done already. How often do you get your shafts greased, should be at every lube job.
Old Jan 26, 2010 | 04:00 PM
fishhawk's Avatar
I took a look just one fitting on the front joint.
I called a drive shaft shop and they want $207.00 to rebuild the shaft and balance. What do you all think.
Old Jan 26, 2010 | 04:13 PM
thats about right. make sure you get 3 greasable u joints and a new centering ball kit. and grease the u joints at every oil change.
you can buy a new Tom Woods for around $300. FYI
Old Jan 26, 2010 | 04:29 PM
With 3 u-joints and a centering ball they may charge a little more and that is OK.
Make sure you lube all your joints every oil change.
Old Jan 26, 2010 | 06:20 PM
devildog01's Avatar
If your at all mechanically inclined you can diy.If you look up "front prop re-build by kevin liu"( I think I found it d-web) there is a complete step by step on how to rebuild it (with pics)and parts needed with part numbers.I did mine and it cost me $80 bucks and took about 2 hours.
Old Jan 26, 2010 | 06:40 PM
fishhawk's Avatar
Any reason to go with one of the Tom Wood shafts over getting mine rebuilt. I do not have a lift and only light off roading to trout streams/back woods. No rock jumping..
Old Jan 26, 2010 | 07:46 PM
devildog01's Avatar
All depends on the depth of your wallet.
