What Size Brake line?
Hello, does anyone know what size brake line land rover uses? The line running to the rear driver side wheel from the front has rusted in two on top of frame rail. Im hoping to get the parts I need local from either advanced auto or autozone. Just unsure of the line diameter and threaded end size. Looks like I will need about 8' of length.
Thanks!
Thanks!
I had to replace the hardpipe from just behind the driver's front wheel all the way back to the passenger rear wheel. It ran next to the same line that fed the driver's rear wheel but it crossed over at about the rear axle. I went to Advance Auto and and bought this PAE-360. I actually bought two 60" pieces and an 8" piece, along with a few couplers and ran it straight back to the soft line that feeds the passenger rear caliper. I had to coil the 8" piece because it was too long, you can feel free to get creative with the lines to accommodate the length, just be sure an bend it with a tubing bender so as not to crimp it. The PAE-3 is the important part, the last two digits are the length of the pipe.
JerrodSteph
Jun 12, 2011 06:04 PM
