What size tools for the drain/fill of autom. transmission?
So I should go and buy a micrometer now... A tape measure would not be accurate enough.
![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
5 and 8 did the trick...
Now, question... I was able to add almost 4.5 quarts. Once it started coming out of the fill hole, it wasn't just a 2 mm bead. It came out like in a (little) stream. I quickly closed it, but now I am wondering if I overfilled it. Is that possible? and if so, is that bad?
