What tools are needed to replace the rear air bags on disco II
Old Aug 28, 2009 | 12:07 AM
landRoverNewbie's Avatar
Default What tools are needed to replace the rear air bags on disco II
Hello,
If anyone could please tell me what tools are needed to replace the rear air bags. I have all the parts I just need to know what type of tools are required.
Thanks
Old Aug 28, 2009 | 05:37 AM
lipadj46's Avatar
I am assuming just the regular old stuff (breaker bar, metric socket set, extension set, wobble extensions, never hurts to have a hammer around) plus a good floor jack and jack stands.
Old Aug 28, 2009 | 05:54 AM
hilltoppersx's Avatar
and disengaging the air bags
Old Aug 28, 2009 | 05:59 AM
lipadj46's Avatar
You should pull the negative battery cable when you do any work with anything electrical like that.
Old Aug 28, 2009 | 08:14 AM
OK, so her is what you need, 2 jack stands, a jack, a couple open end wrenchs and a pair of pliars that's all.
Old Aug 28, 2009 | 10:49 AM
AK Rover's Avatar
And a big friggin' hammer. You need a BFH for every job.
Old Aug 31, 2009 | 06:27 PM
thank you this helps alot!
Old Aug 31, 2009 | 06:38 PM
Urban Panzer's Avatar
This may help a little bit more
http://www.discovery2.co.uk/Rear%20Air%20Springs.html
Old Sep 1, 2009 | 09:00 AM
WOW thank you that is exactly what I was looking for... Do you happen to know the part number for the pin that goes in the bottom of the air bag. I am having difficulties locating this part.
Old Sep 1, 2009 | 10:31 AM
Pin ????
What Pin ?? the bag has the "lock tab" built into it, its simply a twist and turn to remove the whole bag, no pins needed.
