What is what under here?
Old May 29, 2018 | 10:48 PM
TaylorCadence's Avatar
Default What is what under here?
Need a little help distinguishing what bushings are what here, would appreciate your input!
1) track rod
2) panhard
3) drag link
4) ?
5) ?
6) ?
7) ?
8) steering dampener
9) upper front radius
Please correct me if I'm wrong, just giving my best judgement.
And was always curious what the empty holes are where the blue question mark and arrow point too?
Thanks!
Old May 29, 2018 | 10:49 PM
Saturnine's Avatar
I believe 4&5 are the upper and lower ball joints
Old May 29, 2018 | 11:01 PM
Jeff Blake's Avatar
6/7 sway bar
Old May 30, 2018 | 12:04 AM
Icannap1's Avatar
Universal for right hand drive steering. Not used on left hand drive steering.
Old May 30, 2018 | 01:29 AM
LR03NJ's Avatar
X2, steering
Old May 30, 2018 | 04:14 AM
Cool so does this look right then:
1) track rod
2) panhard
3) drag link
4) lower ball joint
5) upper ball joint
6) lower sway bar
7) upper sway bar
And the hole is for right hand drive steering
Old May 30, 2018 | 06:04 AM
Red5's Avatar
Maybe just semantics, but this is what I call it...
Originally Posted by TaylorCadence
1) track rod Drag Link
2) panhard or Track Bar
3) drag link Tie Rod
4) lower ball joint
5) upper ball joint
6) lower sway bar
7) upper sway bar
Old May 30, 2018 | 07:58 AM
OverRover's Avatar
WOW is that rig CLEAN!!!!!!!!!!!!!!!!
8 > DRAG LINK ( w/ Steering Damper mounted to it)
1 > Tie Rod End @ Steering Box Drop Arm
2 > Panhard Rod
6/7 > Anti Rollbar/Swaybar Link End
9 > Radius Arm
4 > Lower Ball Joint
5 > Upper Ball Joint
3 > TRACK BAR ( Plus Outer Tie Rod End )
"BLUE Arrow", where the Drag Link outer tie rod would mount on a RH Drive truck.
Old May 30, 2018 | 01:29 PM
Baha dont be fooled.. it’s covered in power steering and engine oil at at the moment
Old May 30, 2018 | 05:37 PM
I was thinking I need new drag link and tie rod ends, but I've seen a few videos where the rods are SUPPOSED to twist back and forth. Does this mean that they're not in need of replacement?
I'm trying to find my front end wobble but can't seem to find the culprit
