What in the world is this under the TB??? Apparently it needs replacing.
Can anyone give me a heads up as to what this is??? I'm a newb and from what I can tell it is connected to the cooling system. There are two hoses that go directly to the reservoir.
The issue is the Rover is overheating because air and coolant are shooting out of the block that the hoses are connecting. Can anyone advice as to the gasket and what the main function of this is.
Thanks mates!!!
Dustin
Thanks Dusty!...
I'm freaking out because when I was driving my Disco Hit the RED Temp side and then cut off on me. It starts up fine cold but now I'm concerned that the engine is damaged. I know the basics of mechanic work and at best I'm praying that the head gaskets are still intact. I've checked the oil dipstick and there seems to be consistency in the oil, so that is a good sign. Please advice on anyways I can test cooling system to stop overheating.
Engine shows overheating after about 5 minutes of driving due to coolant leak in this throttle block.
Thank you!
Thank you!
yes you can bypass. post #3
but as mentioned, unless it has dripped until you are low of coolant, you likely have other issues. a scanner that will give live data (including your temp) is recommended. lots use ultra gauge, i use scan gauge II. the factory gauge is not a good thing to follow.
