What's the best source for Injector O-Rings?
You dont want to use Vaseoline in o-rings. Vaseoline is petroleum based and causes o-rings to swell and break down. Use silcone grease.
This worked for me. However if you really want to clean the injectors in the Ultrasonic Cleaner you need to activate them while they are being cleaned otherwise they stay closed and most of the inside will not be cleaned like you think.
Rebuilding them takes nothing. Hardest part is getting the old filter out, which is not hard at all with a screw and a vise.
I purchased a used fuel rail and 8 injectors off ebay, cleaned and rebuilt them in a couple of hours.
