What's the best source for Injector O-Rings?
Old Jun 24, 2014 | 11:32 AM
Jared9220's Avatar
Default What's the best source for Injector O-Rings?
I'm leaving this forum and have deleted all my work in this thread.
Old Jun 24, 2014 | 01:11 PM
ralphobell's Avatar
I have used Mr. Injector. Make sure when you reinstall to put some Vaseline on the 0-rings to create a good seal. The ones you found should be fine.
Old Jun 24, 2014 | 03:09 PM
jafir's Avatar
Those o-rings fit probably hundreds of cars with bosch style injectors. There are kits on rockauto with two o-rings in them (for top and bottom) for about $1.50 each kit.
Old Jun 24, 2014 | 03:10 PM
jafir's Avatar
Though that rebuild kit might be a good way to go.
Old Jun 24, 2014 | 03:27 PM
acamato's Avatar
You dont want to use Vaseoline in o-rings. Vaseoline is petroleum based and causes o-rings to swell and break down. Use silcone grease.
Old Jun 24, 2014 | 03:43 PM
dusty1's Avatar
is dielectric sil. based.....I put that junk on them
Old Jun 24, 2014 | 05:15 PM
ralphobell's Avatar
This is true, I stand corrected. Use KY Gel instead.
Old Jun 25, 2014 | 07:07 AM
ralphobell's Avatar
This worked for me. However if you really want to clean the injectors in the Ultrasonic Cleaner you need to activate them while they are being cleaned otherwise they stay closed and most of the inside will not be cleaned like you think.
Rebuilding them takes nothing. Hardest part is getting the old filter out, which is not hard at all with a screw and a vise.
I purchased a used fuel rail and 8 injectors off ebay, cleaned and rebuilt them in a couple of hours.
Old Jun 25, 2014 | 07:12 AM
drowssap's Avatar
a couple of interesting videos,"i"think i'd grab a set of spare injectors at the bone yard and work with those.
Old Jun 25, 2014 | 08:04 AM
SuperSport's Avatar
KY also makes things swell.
