What's the likely source of leaking oil in driver's side front corner of engine bay?
Old 02-20-2014 | 11:29 PM
bcolins's Avatar
Default What's the likely source of leaking oil in driver's side front corner of engine bay?
Thinking it might be my steering box, but thought I would check here to see if there is a common leak in that area. The underside of the truck is newly wet with oil around the general area of the steering box.
Old 02-20-2014 | 11:46 PM
utah95's Avatar
I had a similar issue. While tearing everthing part for another repair noticed when I moved the ACE pump that the underside of the line coming out of the tank had burst, but I could not tell until I was moving the pump and flexed the line. It appears it is under no pressure so a large hole (probably almost an inch long) only leaked slightly until the hose was flexed. I do not know if it is a normal problem, but mine was one that could be easily missed had I not been working on something else.
Old 02-21-2014 | 10:19 AM
dusty1's Avatar
mine had tiny leak at res to p/s pump hose. it was right at the reservoir and looked like it was coming from anywhere but there. I had to put that glow in the dark leak detection stuff in to find it
Old 02-21-2014 | 10:30 AM
ZGPhoto's Avatar
It's usually the power steering box, but could also be the line like dusty said.
croller63
08-30-2014 11:55 AM
Paul3221
11-25-2013 01:12 PM
losinov
12-03-2010 10:20 PM
Princess
09-15-2009 09:02 PM
Quick Reply: What's the likely source of leaking oil in driver's side front corner of engine bay?
