Whats this plug??
Old Oct 14, 2015 | 10:21 AM
Mr R's Avatar
8th Gear
Default Whats this plug??
Passenger heated seat works ok, drivers side not working. Checked fuse ok. Switch light stays on but no heat. Checked under drivers seat and saw this plug unattached, there are 2 wires in the back of it - 1 black, the other red/white stripe. Can't see anywhere for it to plug in to. Is it the answer to my no heat problem? Does anyone know where it goes? Any advice appreciated.
Old Oct 14, 2015 | 10:23 AM
georgep's Avatar
Download a copy of RAV from this site it will help you in the future and now with this question. I will look it up when I get to the shop.
Old Oct 14, 2015 | 12:28 PM
jafir's Avatar
Black and red with white looks to be for the seat belt switch.
Old Oct 14, 2015 | 01:34 PM
PaulMc's Avatar
As already said, that connector (C0100) is for the driver's seat belt buckle switch.
If the tell-tale light on the switch illuminates in the 'on' position - then, there is power to the switch.
With the switch, switched 'on', check that you have a voltage on terminal 1 of the 5-way Brown connector under the seat (Blue/Grey cable).
If you have a voltage at this terminal - then, you should be checking for a voltage at the seat heater module connector -
Orange/White cable on terminal 2, is its input
Pink cable on terminal 4, is its output
If you have a voltage at both of these points - then it's almost certain that one of your seat heating elements has failed open-circuit.
The two elements (seat cushion, and seat back) are wired in series - so, if one fails, neither get hot.
Old Oct 16, 2015 | 05:59 AM
Mr R's Avatar
8th Gear
Thanks for that info. With regards to the belt buckle switch - where does it go? I guess it's not supposed to be loose under the seat as it is?
Old Oct 16, 2015 | 08:02 AM
hokkabaz's Avatar
I have the same question!
Attached Thumbnails Whats this plug??-14450004899451350230181.jpg   Whats this plug??-14450005360341908677473.jpg
Old Oct 16, 2015 | 08:19 AM
BackInA88's Avatar
Those are for a heated windshield.
Old Oct 16, 2015 | 09:43 AM
PaulMc's Avatar
Are you the same 'Mr R' who posted the same question on LandyZone ?
If so, as you're in the UK - the seat belt buckle warning light circuit is not implemented in this market - so, the connector is not connected to anything.
Also, the wiring colours I gave in my earlier post about your heated seat, will not be correct - as, this being a US forum, I gave the colours for the LH front 'driver's' seat.
Old Oct 16, 2015 | 09:55 AM
Mr R's Avatar
8th Gear
[QUOTE=PaulMc;539047]Are you the same 'Mr R' who posted the same question on LandyZone ?
Yes I am Paul! That's good to know about the loose connector - I just saw it dangling around under my drivers seat whilst trying to sort the problem of the seat not heating up. Going back to the heated seat - the fact that the car has hardly been used before I got it, I can't help thinking it's going to be something easy, also the passenger side works ok (according to my wife!). There's only the one fuse for both seats isn't there? The switch lights and stays lit but no heat from the seat. Any ideas?
Old Oct 16, 2015 | 10:48 AM
jafir's Avatar
I'd check all of the fuses and relays first, then I'd start check for power at different locations along the way to the elements.
Oh, also I've seen the power window switches go bad if someone spills a beverage on them, so I imagine the heated seat switches might have a similar sensitivity. Maybe you could swap the two switches and see if the problem changes seats.
