Wheel arch extensions needed!
Thanks for the reply Mike...
The wheel extensions are like this:
http://www.mm-4x4.com/defender----ra...ons-2661-p.asp
I will put 33 inches insa turbo special track tires on the car and also will add 3 inches with a suspension kit.
The size of the tire is this: 285 75 16
Is this what you're looking for?
http://www.lucky8llc.com/Products.asp?ProductID=2148
May not be big enough, but its worth a look.
I believe you have 12 spline axles and will need not only 24 spline but most lockers recommend H.D. axles to prevent damage.
