wheel size????
wheel size????
long story short, i wanna put 20x8.5" rockstars on my 03 DII. i know our bolt pattern is 5x120 (4.72") and they dont make a rockstar in that size.
i've read, though, that a wheel with a 5x4.75" bolt pattern will work. is this true? they make a rockstar in that bolt pattern and they have a 38mm offset option which will work.
Nope, and given the crowd that hangs out here, I'm afraid you're not all that likely to find someone with a certain answer. Most of the regulars here are more prone to pull bling-trucks *out* of places they shouldn't have gone. :-)
Anyone putting 20" rims on a Discovery is probably putting 33" tires on them, and has a different set of problems from yours.
well I just bought a Disco with 19" wheels that I don't much care for, from what I gather they are from a Range Rover, not sure how they got there. Regardless, I've been looking to go smaller and the same issue confronts me. I have been trying to find wheel that'll fit the 5x120, yeah, I can't find anything. So I'm interested as well to know if a 5x4.75 would work, just to figure out what my options are.
i don't mind the ride quality of 20's. also, i don't wheel my disco because i don't want to break anything. i've got a jeep for the hardcore stuff. also, the wheel should fit on my spare tire carrier (285/50/20 terra grappler.. 31x11.5). basically the only thing my disco sees is asphalt, concrete, gravel, grass, snow, and ice. i dont mind if the wheels scratch up either. a black sharpie can fix that momentarily until i can get my buddy to powder coat them all again if it gets too bad.
that being said... is this doable?
