Wheel/Tire suggestions
Old Jul 4, 2016 | 11:37 AM
jringeno's Avatar
Default Wheel/Tire suggestions
So i have 18" hurricanes on my '04 disco 2 and was considering going down to 16's(16x8 to be exact) since i can get them fairly inexpensive from most off road supply stores. I am looking at some ProComp wheels Pro Comp Wheels and Tires 7069-5865 - Pro Comp (Series 7069) 1-Piece Flat Black Finish Alloy Wheel with 5x4.5 Bolt Pattern - Quadratec. They have a back spacing of 4.0. Is anyone running these types of wheels or know if the back spacing will allow for proper clearance?
I am also thinking of wrapping them with some 265/70r16 general grabber AT2's.
If any one has any other suggestions, i am open to any. thanks!
Old Jul 4, 2016 | 11:40 AM
jringeno's Avatar
I should also add, i am putting a TF 2" lift on it.
Old Jul 4, 2016 | 01:53 PM
Best4x4's Avatar
Jeep wheels DO NOT fit a LR. If you stick with the 18's and that 2inch lift either use some 255/70R18's (popular size thanks to Jeep JK/JKU's with 18inch rims) Goodyear Duratrac, BFG KO2's are both available in that size. Or if you go with some LR 16's 265/75R16.
Old Jul 4, 2016 | 04:05 PM
jringeno's Avatar
ok, thats good to know. The other suggestion i got was a 285/60R18. They are a little more pricey, but they are quite aggressive!
Old Jul 4, 2016 | 05:05 PM
dtmbinb's Avatar
275/65r18 will fit good with a lift.
Old Jul 5, 2016 | 03:16 PM
iconoclast's Avatar
If you wind up parting with your Hurricane wheels... I may have interest in purchasing them. Please contact me if and when you decide. Thanks.
Old Jul 5, 2016 | 04:31 PM
samroy92's Avatar
Check out the thread I just posted, I fit 275/65r16's with minimal rubbing. I will probably want to trim the bumper but otherwise they fit OK. I'm happy.
Old Sep 30, 2020 | 01:13 PM
Big Jim Swade's Avatar
Also, realize the taller tire you go with, the more sluggish the vehicle will be if you don't re-gear. A disco isn't much of a power house to begin with and any change in tire height will make it worse driving on the highway, especially if you tow a trailer.
Old Nov 22, 2020 | 12:11 PM
Chris Fleming's Avatar
With the stock 19" rim, if I don't want an "off-road tire" what size works? 275/45/19??? Will that fit or no??
Old Nov 22, 2020 | 12:19 PM
Dave03S's Avatar
The Discovery 2 never came with a stock 19" rim.
Those were only stock on Range Rovers.
