wheels???
Old Oct 14, 2011 | 08:23 AM
drowssap's Avatar
Default wheels???
Anyone know of any non-land rover wheel that will fit on a Disco II?
I'm looking to put on some winter/snow tires and the cost of an 18 snow is stupidly crazy.
So I guess i will drop down to a 16 inch wheel for a better selection of tires, but people want 3-400 for used Disco II rims. So does anyone know if certian year RR fit a disco? and or does anyone have access to a hollander manual to see if another brand interchanges.
Yes; I know being cheap and owning a LR dont go togther, but neither does spending 1000-1200 for snow sneakers for 3 months a year.
Old Oct 14, 2011 | 09:08 AM
Just buy a set od 16" factory take off wheels, you can find them for around $50 a piece.
Old Oct 14, 2011 | 10:07 AM
drowssap's Avatar
that was my plan but they run $75 or more where I am, and if i find them on line for $50.00 i'm back up to 3-400 a set by the time I pay for shipping. Thats why i was wondering if RR or something else will fit, maybe discoII is to specific.
Old Oct 14, 2011 | 10:45 AM
yloDiscoII's Avatar
Range Rover P38 wheels will work.
I've found them for as cheap as $25/each locally.
I've also heard rumor that there is an old Camaro steelie that works, but might require a spacer to correct the backspacing.
Old Oct 14, 2011 | 02:31 PM
It is hard to find good steel wheels for $75 so you may need to raise your budget for these.
Old Oct 14, 2011 | 05:45 PM
drowssap's Avatar
thanks, guys
Old Oct 14, 2011 | 09:40 PM
BMW X5 rims fit, you may need to make the hub hole bigger.
Have you tried your local tire shop for rims? Even a cheap aftermarket rim?
Old Oct 15, 2011 | 06:46 AM
tee51397's Avatar
You need a 5-120 PCD and the center hole is 70mm. Barring some crazy offset anything with those dimensions will work. You can also check for 5 - 4.72" which is basically the 120mm equivalent in inches and have heard that 5 - 4.75" will fit as well but I can't confirm it.
Doubt you're going to find anything too much cheaper than used LR though.
dwaned
Feb 6, 2010 03:01 AM
porwig
Feb 25, 2008 10:34 AM
porwig
Feb 25, 2008 10:22 AM
Kooner
Aug 28, 2007 04:51 PM
disco12
Feb 14, 2006 11:35 PM
