Wheels hard to remove
Old Oct 7, 2011 | 08:26 PM
0304Disco's Avatar
Default Wheels hard to remove
I was removing the wheels for a front brake job and ran into some wheels that did not want to release from the hub. After I removed the lugs I had to beat the wheels off using a sledge hammer and a piece of wood on the back side lip of the rim. Even using a 5 lb sledge I had to beat the heck out of both wheels to get them off.
If I ever got a flat tire I would have never got these wheels off on the side of the road.
When I reinstalled the wheels I use grease on the hub hopefully to prevent this problem in the future.
Old Oct 7, 2011 | 08:38 PM
jafir's Avatar
Stand facing away from the wheel, bend your leg at the knee, and kick. Or sit on the ground, and kick it with a good stomping motion. It will pop right off. No need to hammer from the back side.
The hubs are steel and the wheels alloy, so they build up a little corrosion after a while. You could probably put a little bit of anti-seize on the hubs, to help it out in the future.
Old Oct 7, 2011 | 09:11 PM
boris_gti's Avatar
Aluminum rims tend to build up oxidation.
Like other person said....put some grease or anti-seize compound on the hubs.
Old Oct 7, 2011 | 11:23 PM
lordmorpheus's Avatar
Was planning to post a solution, but too late. The solution has already been covered.
Old Oct 8, 2011 | 09:03 AM
These will help prevent that.
Land Rover Parts, Accessories and Information
Street Wolf's Avatar
This being one of the reasons I carry a large bottle of anti seize in my Disco as part of my quite extensive tool kit.
That...and when god himself could not remove a wheel hub from an axle I was replacing one time.
Old Feb 2, 2013 | 12:45 PM
JamesB's Avatar
3rd Gear
Thread revival time.
I've just spent a few weeks replacing the front disc rotors and pads and the left hand hub.
The front wheels were last off the car about 3 years ago when all the tires were replaced, so while the mechanical repairs took less than a day, most of the time was spent in an increasingly more frustrating time as I tried to get the front wheels off. In that time, the weather turned from a nice 15C day when I started the job in the open on the driveway to a few -15C days with snow.
I had a similar battle with stuck rear wheels when I did the rear brakes 2 years ago, and I smeared a copper based anti-seize compound on them as a preventative measure (I'll see how well that worked when I remove the rears in the next week or so).
There's lots of discussions on the 'Net about LR alloy wheels sticking to hubs, and all the recommended preventative measures.
I have a lot of contacts in boating communities in Australia, and dissimilar metal corrosion is a major discussion topic (especially the reaction between aluminium and stainless steel). In discussions with them, there were two products that kept getting mentioned as a possible solution to the LR wheel sticking problems:
Has anybody tried these products on their wheels?
Old Feb 2, 2013 | 01:16 PM
taylor15's Avatar
3 years? No rotations?
Old Feb 2, 2013 | 01:25 PM
Externet's Avatar
That extreme difficulty to remove wheels was my first hurdle when I bought mine (unused, parked for a year).
Decided that will never happen again and less at the roadside, with a round file, removed a frog's hair material off the wheels alloy hole, making the center never sticking again. Mounted on the hubs well greased.
Old Feb 2, 2013 | 01:28 PM
ZGPhoto's Avatar
You live in canada and haven't had new tires on in 3 year? What about snow to summer?
