When is does the ODB throw a CEL?
Old Jan 11, 2010 | 06:18 AM
04BluDisco's Avatar
Default When is does the ODB throw a CEL?
When does the ODB throw a CEL? Specificially, if the O2 sensors are bad (any of the 4), does it throw a CEL? Or, does it just manifest itself as poor mileage? Also, does a failing MAF cause a CEL to be thrown as well? Just curious under what parameters these occur.
Old Jan 11, 2010 | 10:04 AM
lipadj46's Avatar
When the voltage stops changing on the O2 sensors it throws a code. If you watch an O2 sensor live with a scanner a good one will have the voltage jump all over the place as the O2 conc. changes but a bad sensor will stay at one voltage or respond very slowly.
Old Jan 22, 2010 | 02:09 PM
04BluDisco's Avatar
maybe I should ask it this way... I am thinking I should be getting better mileage.... I am getting around 15 ish mpg.... but I wondered if something could be contributing to that without throwing a CEL code....
Old Jan 23, 2010 | 10:04 AM
How many miles on your truck, have you replaced your factory plug wires, what octane gas do you use, what air pressure in your tires? All these will contribute to your mileage and 15 is not bad, many get a lot worse.
Old Jan 23, 2010 | 02:22 PM
04BluDisco's Avatar
76K ish on the truck. I put magnecor 8mm on it, and use 93 octane always.. Tire pressue... usually I run at 40 front, 45 rear
operez818
Feb 14, 2009 09:34 AM
rover_lover
Nov 11, 2007 02:53 PM
Tvdmtac
Sep 5, 2007 09:42 AM
95DiscoSE7bullitt
Jun 1, 2007 09:02 PM
s4lex
Feb 16, 2007 04:41 PM
