where to DL rave cd easily?
RE: where to DL rave cd easily?
Then you'll be left to getting a copy from eBay, or find someone who will send you the extracted version on cd. It's not very difficult, but the steps can seem daunting. It's easier if you understand what you are doing instead of just following a long list of steps.
What you download from Green Oval is a .iso file, commonly referred to as an image file. It's a format that contains all of the files you would have burnt to cd, contained in that one .iso file. Kinda like a .zip file except there's no compression going on.
There are apps that read the .iso file like Alcohol 120%. This app will add a virtual cd drive (it will look like you have 2 cd drives). You can then "mount" the .iso file and read the contents like you had inserted the physical RAVE cd.
medicfernando
11-25-2012 10:42 PM
