Can rear A/C be added fairly easily?
Old Sep 17, 2012 | 12:18 PM
Joshman's Avatar
Default Can rear A/C be added fairly easily?
Searched the forum, couldn't find any posts on it. We have 5 kids, so I am trying to add rear seats, and thought it might get warm back there. Has anyone added rear AC? Could I retrofit with stuff from a junkyard donor?
Old Sep 17, 2012 | 12:27 PM
grandkodiak's Avatar
You could just tape up some pvc from one of the existing rear vents and have it go to the trunk area.
Yes, it can be retrofitted from a donor as long and you can find one with the same interior color so you finish with all the same color on the interior.
How mechanical are you?
If you want some help with tracking down some parts, get back to me.
Old Sep 17, 2012 | 12:31 PM
Joshman's Avatar
I have no vents in the rear at all, so I would be adding to the second AND third row (I think). I haven't been able to find good images of where rear AC is located on trucks so equipped.
Old Sep 17, 2012 | 01:25 PM
drowssap's Avatar
yes; it can but not easly you would need to have a complete donor vechicle.
you have duct work and controls above the head liner, you have ducts in the head liner, the rear evaporator and blower mount in the rear drivers side behind the jump seat, (which is different than a regular jump seat panel), then you have to marry the refrigeration lines into the main AC system. You can do it but it will be a lot of work.
Old Sep 17, 2012 | 05:08 PM
Joshman's Avatar
Sounds like more than I want to tackle for now. Thanks guys.
Old Sep 17, 2012 | 05:43 PM
coors's Avatar
There's more than just running duct lines and mounting a blower motor. If you're not in tune w/ the fundamentals of the automotive refrigeration system I would say leave this one to the pros. You run the risk of damaging your A/C system.
But, if you're confident enough to tackle the project, more power to ya. I believe if you search a little further there are a couple threads on here where the retro has been discussed. If you run into any issues you can always come back here. We'll help.
Old Jul 27, 2015 | 04:13 PM
badassbmwm3's Avatar
Default Wiring?
Are all trucks pre-wired for the above controls and blower and all back there?
Old Jul 27, 2015 | 04:26 PM
OffroadFrance's Avatar
The short answer is no. Unless you have a complete rear A/C donor truck and be prepared to strip out much of the interior of both your own and the donor truck and install the rear drivers side kit and trim plus the vents, rear ducts and controls in the rear two rows of seats and the wiring which may or may not be there already it is doable but is it worth it on an old D2 truck? Mine has full A/C climate control front and rear to all three seat rows (7 seater) and it's rarely used in the rear seats apart from on excessively hot days. Depends how mechanical you are and whether you desperately want/need rear A/C.
Old Jul 27, 2015 | 04:33 PM
X1 maybe 3-5 full days of work plus an A/C recharge assuming the wiring is there already. It would be easier to buy another truck with rear seats and rear A/C IMO. Rear A/C trucks obviously hold more fridge gas and oil.
PS sorry to be a downer but it's a fact.
LR3Philly
Jul 6, 2014 02:23 PM
medicfernando
Nov 25, 2012 10:42 PM
Camdisco24
ROAMING WITH FRIENDS
Jan 15, 2010 10:50 PM
tornado_735
Nov 9, 2009 06:35 PM
sloppyjoe
Dec 23, 2008 06:26 PM
