Where does the small black plastic vacuum line by over the brake booster go?
Old Jul 27, 2013 | 07:41 PM
bcolins's Avatar
Default Where does the small black plastic vacuum line by over the brake booster go?
Getting my 03 D2 back together, and noticed that there is a small diameter black plastic vacuum (I'm assuming it's a vacuum line) that comes up along the outside of the brake booster then turns and heads over the top of the brake booster towards the drivers side valve cover and is currently just hanging there with nothing (that I can see) to connect to it.
Should this line connect to a module, vacuum solenoid, rubber hose, or......other? Or, should it just be hanging there, open to atmosphere. Thinking if it should be open to atmosphere,.....it should at least be pointing downward like the one on the passenger side of the engine against the firewall.
Can someone pop the hood on their 03 and see if you can help me answer this question?
Thanks in advance,
Brian in Austin
Old Jul 27, 2013 | 10:05 PM
Dan7's Avatar
It hugs the firewall and comes forward on the passenger side to plug into the upper intake manifold. Mine has a red ring where it plugs in, and it just pushes in.
Old Jul 27, 2013 | 10:54 PM
CCRovers's Avatar
I think the line you are referring to is the front axel breather line. It should be clipped near the top of the firewall on the drivers side.
Old Jul 28, 2013 | 09:04 AM
bcolins's Avatar
Is it horizontal and open to atmosphere?
Old Jul 28, 2013 | 09:33 AM
CCRovers's Avatar
Yes it is.
Old Jul 29, 2013 | 10:57 AM
drowssap's Avatar
diff vent
zappy
May 20, 2021 12:43 PM
clint70
Dec 30, 2014 10:28 PM
ljdiscovery
Jan 1, 2014 02:04 PM
Roo
Freelander
Jan 8, 2009 09:32 AM
