Where to find "Heavy Duty" Shuttle Valve
Old Jan 10, 2012 | 09:36 AM
Street Wolf's Avatar
Arrow Where to find "Heavy Duty" Shuttle Valve
I'm activley throwing "114:Shuttle Valve Electric Failure" and I don't want to order just the basic replacement part. I remember that there is a better shuttle valve out there that a company makes, but I can't seem to find the website that sales it. Anyone know where this is?
Old Jan 10, 2012 | 09:53 AM
jafir's Avatar
I've never seen anything but the wabco parts.
This one is the valves with the switch:
Land Rover parts, spares, Land Rover accessories - Search results for SWO500040
This one is just the swtich:
Land Rover parts, spares, Land Rover accessories - Search results for SWO500030
(and it's a little cheaper here: ABS Modulator Shuttle Valve Switch | Brake Parts for Land Rover & Range Rover )
Old Jan 10, 2012 | 09:55 AM
jafir's Avatar
If doing just the switch (and Josh's wiring repair) you'll probably want to replace the seals too: Discovery shuttle valve seals & new style reaining clips
Old Jan 10, 2012 | 10:37 AM
I'm pretty sure my entire problem is actually caused by Josh's "fix". The product Falcon Works sales is actually what I had in mind though, but I'm not going to be cutting it up to perform the fix to it.
Old Jan 10, 2012 | 11:03 AM
bosshogt's Avatar
Why not replace the shuttle valves and do the Option B fix. I have rented the ABS Amigo to over 30 people in the last two years. It always seemed to work for them.
jafir's Avatar
Then you won't be fixing anything, most likely. Most dealers won't even install just the switch anymore, because the problem actually lies in what the switch plugs into, most of the time.
Also, their switch is overpriced.
Old Jan 10, 2012 | 11:07 AM
jafir's Avatar
If you want to spend big bucks, and not hack anything, but still resolve the problem, buy part SWO500040.
Their wiring inside it will probably fail at some point in the future though, unless they've updated their manufacturing processes.
Old Jan 11, 2012 | 09:16 PM
Anyone have any idea why something such as turning my headlamps on can sometimes immediately trigger my three amigos fault?
Old Jan 12, 2012 | 06:17 AM
ebg18t's Avatar
I noticed thats what triggered mine too. I am thinking that ground somewhere is not perfect. I am going to try and check my grounds this weekend. I beleive spike555 posted an image recently of the primary grounds.
Old Jan 12, 2012 | 07:42 AM
Go have your charging system tested, if under 13.6 volts with the lights on, that is your problem.
