Where is the jack lug wrench located?
Old Sep 30, 2010 | 01:24 PM
agthird's Avatar
Default Where is the jack lug wrench located?
in the battery tray?
Old Sep 30, 2010 | 02:17 PM
csbd's Avatar
That's where mine is. I think you'll find it a bit inadequate though.
Old Sep 30, 2010 | 02:26 PM
lordmorpheus's Avatar
Mine is in the tote with the wheel chocks in the tailgate door (tight fit though).
Old Sep 30, 2010 | 02:27 PM
agthird's Avatar
okay thanks...
Old Sep 30, 2010 | 03:41 PM
timdunbar's Avatar
Mine is in the tote with the wheel chalks in one of my side bins in the cargo area.
Old Sep 30, 2010 | 03:55 PM
lipadj46's Avatar
Do yourself a favor and get a 24" breaker bar from Harbor Freight and a 27mm or 1 1/16" 6 sided socket and keep that in the back. If your lug nuts are damaged you may need a 28mm socket. You will just end up hurting yourself if you try using the factory tire iron.
Old Oct 1, 2010 | 09:20 AM
agthird's Avatar
lol...okay
Old May 3, 2021 | 01:22 PM
Lcagee's Avatar
this is good advice. I was using such a setup today. I used a long metal tube over the breaker bar for extra leverage. It was a part from a trampoline. And it was still almost impossible to budge it. Finally got it after about 20 tries. I don’t recommend an impact gun but in this case I used it a little bit. You can strip off the lug nut cap if you don’t use a 6 point socket.
Old May 3, 2021 | 06:36 PM
mln01's Avatar
Wow. Is this a record for a zombie thread?
But as a serious response, I am frequently frustrated trying to remove fasteners that were ridiculously overtightened. Buy an inexpensive torque wrench (e.g. Harbor Freight) and tighten the wheel nuts to 103 lb.-ft. as specified.
Old May 4, 2021 | 04:26 AM
Fallstaff's Avatar
Agreed. Particularly the torque wrench.
but skip the imperial socket and just get the correct metric one.
And I always tell mechanics not to use air tools on the lugs, rips the hell out of them.
