Where is this leak coming from?
Old Apr 19, 2018 | 04:37 PM
escott16's Avatar
Default Where is this leak coming from?
i noticed i have a water leak above my right rear passenger door, where could this be coming from?
Old Apr 19, 2018 | 04:58 PM
Best4x4's Avatar
Sunroof drains are my guess.
Old Apr 20, 2018 | 12:10 PM
Disco_Dion17's Avatar
I have a leak that is coming from the sunroof I believe. Any advice on how to access the drains to try and clear them? Also, where to the drains run to???
Old Apr 20, 2018 | 12:12 PM
redrover75's Avatar
Default drains
I am sure there are many youtube videos to search, this forum, etc.
They are in the corners of the sunroof. I have heard of people using compressed air to clean them, that can blow apart the drain.
i have used weedwacker plastic line to shove down there to push it out.
Old Apr 20, 2018 | 12:18 PM
THANKS! I will give that a shot. See what comes of it. I am hoping it is just a clog and not a broken/cracked nipple where the drain hose attaches. I am not ready to tackle pulling the headliner off just yet!
Old Apr 20, 2018 | 01:38 PM
Richard Gallant's Avatar
Be gentle if you are trying the weed whacker line method. I would suggest putting you line in hot water for a few minutes to make it a bit more flexible.
If you hit a obstruction, pull back and exert very gentle forward pressure. Any blockage should be trivial.
Old Apr 20, 2018 | 02:30 PM
LR03NJ's Avatar
this is regarding the rear sunroof drain. The end of the tube is located at the rear behind the signal light housing on the body not the bumper.
Old May 17, 2018 | 08:03 AM
escott16's Avatar
Default Update on leaking , new leak
while I made a right turn ounces of water poured out of my roof by the front light behind the plastic in the middle
Old May 17, 2018 | 09:37 AM
mollusc's Avatar
Front sunroof this time. There are dozens of threads on here about trying to fix them.
Old May 17, 2018 | 01:29 PM
Motorhead1's Avatar
No, that's not correct, their is a thousand million threads on here about sunroof leaks....
