Where to order brake master cylinder from?
Old Aug 7, 2018 | 11:53 PM
Sub-arctic Rover's Avatar
Default Where to order brake master cylinder from?
I need to order a brake master cylinder for a 2000 disco II. I did some research and it appears people tend to like TRW's (new, not rebuilt).
I found one on parts geek for $195, free shipping (W0133-1651660) . I've never ordered from parts geek before. Anyone have any input?
If not parts geek, who?
Atlantic British is $237.00 w/ shipping
Thanks.
Old Aug 8, 2018 | 01:50 AM
JUKE179r's Avatar
I bought a Britpart brake master cylinder repair kit #SJJ100362 for about a 3rd of the price of the whole assembly. It's been working great for the past 3 years.
Old Aug 8, 2018 | 05:45 AM
mln01's Avatar
https://www.lucky8llc.com/collection...ster-cylinders
Old Aug 8, 2018 | 06:27 AM
OffroadFrance's Avatar
I used a Bearmach/Britpart unit, they appear OK. Replacing the seals is a waste of time as they only supply part of the internal seals not both. They do supply the reservoir seals with the kit but only one internal seal, in fact it's the wrong seal, it's the LP seal.
Old Aug 8, 2018 | 09:36 AM
CollieRover's Avatar
True this. While you are there replace the whole master cylinder. My rebuild leaks when it is cold.
Old Aug 8, 2018 | 10:11 AM
Best4x4's Avatar
For a while you could get the rebuild kit for 45-50.00 and that was fine if all you needed was the reservoir seals. Now those kits are 70-80.00 and a new aftermarket MC that has a different reservoir seal design and is made out of aluminum vs steel. I’ve got one aftermarket MC on my 99 D2 and I prefer it to the OEM unit. New MC’s are 100-150.00 normally.
Old Aug 8, 2018 | 10:16 AM
mln01's Avatar
I rebuilt my brake master cylinder using a kit 5½ years ago. It was fiddly and troublesome, and in the end I wished I had spent the extra money and just bought the full master cylinder ($129 from Lucky8, shipped, linked above).
Anyone truly budget conscious can hunt down the O-rings-only, sold for some Audi model. The part number is out there somewhere at an Australian Land Rover site, I recall.
Old Aug 8, 2018 | 09:26 PM
Thanks to all for the replies!
Lucky8 will not ship to Alaska so that's out. I think I will put the mc on hold anyway. I rotated my tires last night and checked the brakes. Rotors and pads are very worn all the way around.
I will replace the rotors and pads before I worry about the mc. I don't think changing the rotors and pads will change the brake pedal feeling like the mc is bypassing internally, but it's possible.
Old Aug 8, 2018 | 09:50 PM
OverRover's Avatar
If your pads and rotors are very worn causing the caliper pistons to be overextended then it will improve pedal feel once replaced.
And you still might very well need a MC, but if the pistons are not returning/ plus the caliper guide pins are full out the pedal pressure will feel like crap.
Also IF one of the pistons are stuck and not just overextended then again the fluid will have a hard time returning.
Once you open this up it will be very easy to spot if a caliper piston is stuck, or just overextended trying to compensate for the worn pads. And inspect the rubber brake hoses really well too.
Good Luck!
Old Aug 9, 2018 | 05:53 AM
mln01's Avatar
Really? That's interesting. Alaska is still part of the United States, isn't it? Doesn't the USPS serve Alaska? I'm not really doubting you; I'm just surprised to hear this. I understand cross-border shipping to Canada can be a pain, but I didn't know about Alaska.
