WHerecan i find rims
Old Nov 9, 2010 | 11:26 AM
billymoto25's Avatar
4th Gear
Default WHerecan i find rims
hi im lookin for a set of 10 inch wide rims that i can rap some 33x12.50 tires on and can not find anywhere that has any for a discovery 2 cause of the bolt pattern can anyone help me that knows a website or something to buy some
Old Nov 9, 2010 | 12:21 PM
hilltoppersx's Avatar
not sure what size rim you are looking for but Justin just threw some 33x12.5 Nittos on his stock 18's AKA Hurricanes.
http://www.facebook.com/#!/photo.php...9.123570148926
Old Nov 9, 2010 | 12:50 PM
bosshogt's Avatar
I think the steel rims I see people have on the Discoverys are 16"s. I think that is the smallest you can go.
Old Nov 9, 2010 | 01:02 PM
agthird's Avatar
you can find them it's the right deal that's hard to find....
Old Nov 9, 2010 | 02:09 PM
yloDiscoII's Avatar
Only 8" width but, these are a good alternative to stock Rover wheels. Very similar to the ones on AB. I've never seen a 10" rim with the DII bolt pattern.
http://www.okoffroad.com/stuff-wheel-lr.htm
I don't think you necessarily need a 10" wide rim for a 12.50" tire, do you?
Old Nov 9, 2010 | 03:14 PM
First why do you want that big a tire? What do you have for a lift, diffs. And axles? You will also need wheel spacers and a lot of sheet metal triming.
Old Nov 9, 2010 | 04:13 PM
russdouble's Avatar
Why do you want rims that wide for a 12.50 tire? You will need to watch your bead if you air down... or better yet just don't air down. I used to run a 10in rim on my Jeep but I was running 14.5 Mickey Thompsons. An 8in rim with the proper backspacing will serve you much better, and will look better.
Old Nov 9, 2010 | 07:06 PM
Long Haul's Avatar
Im running 33x12.50's on a 7" 16"wheel never had a problem......But I usually dont have more than 20psi in the wheels either.
But to answer your question Justin at www.lucky8llc.com can order them in any backspaceing and width you want, there steel if that makes any difference to you
Old Nov 10, 2010 | 06:28 AM
Brian, wait till you see Justins new truck on Friday, i think he put D1 axles and mounts on a D2 so he could use a TF 3" lift to fit 33's under it. or something crazy like that.
Old Nov 10, 2010 | 07:29 AM
Long Haul's Avatar
Yeah Ive been watching the build up on FB im stoked to check it out. I think I bought enough parts off of him last week to probably pay for that build lol
