Whining
Old Jul 9, 2007 | 11:10 AM
morganmfoster's Avatar
7th Gear
Default Whining
I have 1999 Dico II with 121,000 miles on it. When it gets up to 55mph it has a loud whine while I am accelerating but stops when I let off the gas. Am I going to have to replace the transfer case soon?
Old Jul 9, 2007 | 01:08 PM
98roverguy's Avatar
Default RE: Whining
Maybe u-joints. Ever replaced them or aware of thier replacement?
Old Jul 9, 2007 | 02:22 PM
7th Gear
Default RE: Whining
As far as I know they are original. i just bought her about a month ago. Are the u-joints hard or expensive to replace?
Old Jul 9, 2007 | 04:49 PM
98roverguy's Avatar
Default RE: Whining
They probably aren't the original or they would have grenaded the transmission by now. They aren't too exspensive but dependin on your tech background you can drop the drive shafts and bring them to a machine shop and have the new ones be pressed in. If you want to do it your self you need to have a clamp. U-joints need to be replaced around every 60,000 miles or so, so your definitly up for a swap. I would suggest not driving the vehicle because they can seize up and destroy your tranny. Replace them as soon as possible. Thats my best guess as far as the whining goes. Replace the u-joints since you have to anyway and get back to us afterwards if your still having probs.
Old Jul 9, 2007 | 04:51 PM
Default RE: Whining
When was the last time you changed your diff and t/case fluids as well as lubed the u-joints?
There is a possibility you are about to loos a diff, they are a weak spot for Rover.
You might want to send me your tele number and I'll call you, walking you thru what to check.
Mike
mikeljacobs@comcast.net
Old Jul 10, 2007 | 03:55 PM
7th Gear
Default RE: Whining
I'm going to try to do all that this weekend. I am hoping it is not something major because I cant afford to put too much money into her, and I'm not much of a mechanic myself. Will I need a pump or something to change the t/case fluids?
Old Jul 10, 2007 | 04:01 PM
98roverguy's Avatar
Default RE: Whining
I havn't worked on a D2 but I needed a pump to get the fluid up into the transfer case fill plug. Kind of a hassle and can be messy.
ggushee
Sep 30, 2015 08:49 AM
newlydiscovered
Dec 6, 2006 12:29 AM
tbarker13
Nov 16, 2006 02:22 PM
kfordric
Sep 25, 2006 04:45 PM
lenra
Dec 9, 2004 06:09 AM
