Whining sound? Pulley?
My 01 D2 has a loud whining noise from the front top? of the engine. Changes with RPMs. If I were guessing I'd say it was a pulley somewhere in the serp loop.
Is there a common one that goes bad? My belt is looking old, i may be looking to replace that anyway, so is there anything else I should do with it?
Thanks!
Thanks!
There are 2 idler pulleys and a belt tensioner. Looks like this> Land Rover Belt Tensioner Kit: Discovery 2 And Range Rover P38
1 Idler lives under the belt tensioner and the other under AC compressor. Like this> Serpentine Belt Routing Diagram For Discovery Series 2
And a vid> How To Replace Serpentine Belt On Discovery 2
Could be the compressor. Another [more dangerous] way to diagnose these issues is to start the truck and place one end of a long tool against the compressor. Put your thumb over the other end of the tool and press your ear against your thumb. You'll hear a whine if the compressor has a bearing failing. If you don't hear a whine, you can try to push the tool against other accessories and pulleys to find it.
If the comp is bad, contact Paul Grant for a used one. He's a good dude, I've bought several things from him.
