Whining sound? Pulley?
Old Feb 9, 2015 | 07:20 PM
  #21
dr. mordo's Avatar
That looks good. Be sure to get the TD5 180 degree thermo. Buy OE, because the aftermarket thermos fail frequently.
You should also do a coolant flush and refill with green universal coolant.
Old Feb 9, 2015 | 08:03 PM
  #22
Broken08's Avatar
I was wondering what the coolant of choice is. Why not go with the extended life fancy stuff?
Old Feb 10, 2015 | 05:35 PM
  #23
jfall's Avatar
Try this test..
Carefully
Been there.
Done it.
Lived thru it.
Old Feb 10, 2015 | 05:47 PM
  #24
dr. mordo's Avatar
It's a controversial topic, but Dexcool is known to destroy radiators.
http://www.sancarlosradiator.com/dex-cool_pics.htm
Old Feb 10, 2015 | 07:22 PM
  #25
Broken08's Avatar
Originally Posted by jfall
Try this test..
Carefully
Been there.
Done it.
Lived thru it.
If it is the PS, does that mean a new pump or just bearings? What does that set you back?
Old Feb 10, 2015 | 07:32 PM
  #26
dr. mordo's Avatar
Most power steering pump issues you hear the sound change when you turn the steering wheel.
My reman ps pump was a little over $100 off ebay.
Old Feb 10, 2015 | 11:05 PM
  #27
Broken08's Avatar
Hmm, I don't hear a change when turning the wheel. I'll pull the serp asap and spin things by hand and see if anything is weird. Just have a rought work schedule this week.
Thanks all for the input so far. I will update.
Old Feb 27, 2015 | 05:12 PM
  #28
Broken08's Avatar
I was in for a key programming and the tech said it was the ACE pump "ready to fail". I haven't gotten to the serp belt yet as I'm waiting on a few more parts, so I can't yet confirm
Old Feb 27, 2015 | 07:42 PM
  #29
Fallstaff's Avatar
That video scares the pants off me!
I'll eventually need to figure out the groaning in my steering, but if it takes that, I'm out.
Old Feb 28, 2015 | 07:46 AM
  #30
CollieRover's Avatar
The way I bang my knuckles while working on this truck there is no way I would do that. Not for the faint of heart. Seems that with the same amount of effort and less danger just take your fan belt off and spin the pulleys. I had a bad one and on mine visually you could see that it was worn out.
