Whistle Sound When Reving - Only in Park
Hey gang,
After letting my disco sit for a while i'm finding all kinds of gremlins. Most have been sorted.
Here's a new one.
When the car warms up, if I rev the engine, while in park. The engine makes a high pitched whistling sound.
If I put the parking break on and put it in Drive or Reverse the sound doesn't occur.
Wondering if anyone else has had this issue. I searched for a vacuum leak and found nada. Used a stethescope and can't pinpoint it either.
I read some threads on LR2s having a PCV valve that goes out and produces a similar sound.
Anyone ever encounter this?
Here's a new one.
Ok so this is now happening even when in park. Went to go get the truck smogged yesterday and just a mile from home this high pitch sound wouldn't go away.
From other posts it can be a slew of things.
- AC Compressor
- Alternator Bearing
- Belt tensioner
- Fan Clutch
- Powersteering
Took a video from off to start, to revving, to off again to see if anyone can point me in the right direction.
When the AC is turned on it just slows the squeal.
Power steering fluid is full and no leaks.
Any and all help appreciated.
- AC Compressor
- Belt tensioner
- Fan Clutch
- Powersteering
The alternator stops spinning at exactly the same time that the rest of the accessories do. Before buying parts, get one of the cheap stethoscopes from Harbor Freight and start poking around. Those actually work really well when trying to pinpoint the source.
Have you tried running the engine without the belt? That would eliminate all of the accessories and pulleys if the sound remains.
Just took a few things apart, and noticed the lower right throttle body bolt was a bit loose. Tightened it all up and the whistle isn't as pronounced, so it was definitely part of the problem.
Sound is coming from the top of the engine when it does happen, so it's none of the accessories, thanks for pulling me back from that ledge.
Hoping to put some miles on the truck tomorrow night to complete the drive cycle for smog and see if anything else comes up.
