Whistle while driving
Old Nov 15, 2015 | 08:18 PM
jrwalk1651's Avatar
Default Whistle while driving
Lost here...I have a resonating whistle sound while I'm driving, it speeds up when I give it more gas and gets quieter when I let of the throttle can't wrap my head around what this is. Sometimes I will be off the throttle and it still makes the noise. Any ideas??
99' discovery
VIDEO: http://youtu.be/naegqE0HI2k
Old Nov 15, 2015 | 09:20 PM
Wilson7287's Avatar
99' discovery
Does it make the noise when you aren't driving down the road and just rev the engine up slowly?
Old Nov 16, 2015 | 06:09 AM
jrwalk1651's Avatar
No it doesn't.
Old Nov 16, 2015 | 11:19 AM
acamato's Avatar
Did you check the vertical door window felt seals? They typically slide down and make noise because of the air movement.
Old Nov 16, 2015 | 11:23 AM
dgi 07's Avatar
If I'm reading correctly (which may not be the case due to the massive hangover I'm suffering from) it seams to be a drive train issue. The vehicle is still moving when he let's off the throttle.
Obvious checks have been completed? Driveshaft u joints, diffs and wheel bearing?
Old Nov 16, 2015 | 12:13 PM
jrwalk1651's Avatar
I'll have to check the bearings (it doesn't really sounds like bad bearings though) also just greased the drive shaft and replaced the diff fluid and transfer case fluid yesterday.
Old Nov 17, 2015 | 09:10 AM
dgi 07's Avatar
does it sound like drivetrain or does it sound like a body related noise>\
Old Nov 17, 2015 | 10:16 AM
andy13178's Avatar
have you had a look around your exhaust manifold? my d2a had a whistle and it ended up being the manifold leaking after I had spent $1000s on changing things good luck
Old Nov 18, 2015 | 07:14 AM
jrwalk1651's Avatar
I'm guessing it's drive train but it doesn't seem very consistent. Sometimes are louder than others. I'm going to check the drive shaft again. Or maybe throw a GoPro under the body to see if I can pinpoint anything.
Old Nov 18, 2015 | 10:44 AM
cappedup's Avatar
I first thought exhaust manifold when you said whistle, but watching the vid it's more a squeak or chirp I would say.
If drive shaft is greased, I would look at wheel bearings, although I have no experience of them with discos. Jack each corner and see if you have any odd wobble.
I've just replaced my guide pins in the calipers which cured a squeak I had. Kinda similar to your noise. Cheap, easy and another thing to tick off as 'done that'. I can almost imagine a slightly warped disc/rotor making that cheep noise, if the pins were bad. Any vibration with braking?
