Who knows cruise control? 2001. Help
The following 2 users liked this post by mollusc:
Greg Vasileff (11-16-2017),
JUKE179r (11-16-2017)
OK, ... I read that this happened to someone else. Thought they posted here, but I don't see it now.
Cruise Control will NOT Set when my radio is turned on. Well, ok then.. If I turn the radio off I can Set it, but when I turn the radio back on it soon shuts off the Set.
Thoughts? Will pull the steering wheel today I guess being the commonalities could be in this clock spring.?
I’d say yes. New ones from Atlantic British are a bit over $300.
On your specific issue, I can’t really speak as I’ve not yet programmed the controller I got with the aftermarket stereo yet to work with the OEM steering wheel controls, but my horn works perfect in addition to the cruise and I don’t get any SRS codes (the air bag also goes through the clock spring).
In regards to CC troubleshooting, and the "clock spring" that is mentioned. Is that only for the cruise control buttons, or all steering wheel buttons?
Asked another way, if my radio buttons on the steering wheel are working is it safe to assume that the "clock spring" is functioning correctly?
On my CC I get the light on the cluster button but when I pull the button on the steering wheel I get nothing. No click or noise at all. Radio controls on the steering wheel work.
