Whole hub is loose in front - Video
Old Jan 8, 2013 | 09:37 PM
chadil1ac's Avatar
4th Gear
Default Whole hub is loose in front - Video
Hey all, I'm new to this forum but not forums in general. I am coming to you to figure out what is going on with my 2002 Disco. Recently I noticed a rubbing in the front right wheel so I took the wheel off and the brake disc/hub have a lot of play in it. I don't know where to go from here and am not sure what is causing this problem. I can actually see the movement start to go into the axle past the (what I am guessing are U-Joints but not sure, maybe CV) and it's pretty loose in there.
Here is a video to show the issue.
Old Jan 8, 2013 | 10:14 PM
Fivespddisco's Avatar
your hub is beyond bad. The bearing inside the hub is smoked causing your rotor troubles. I would not recommend driving the truck until it is replaced.
Old Jan 8, 2013 | 10:27 PM
buick215's Avatar
I suspect that it is the bearing as well. How many miles does your truck have?
Old Jan 8, 2013 | 11:04 PM
chadil1ac's Avatar
4th Gear
Yeah, I had a friend come check it out, he suspected bearing. I didn't think the bearing would make it that loose. I am in the process of replacing it but it's too dark and cold here tonight so I will work on it again in the morning.
The truck has 101,000 miles on it. I definitely won't be driving it until the bearing is replaced.
Humdinger
Dec 2, 2013 04:26 PM
jrm123180
Mar 17, 2010 10:34 PM
robot808
Nov 18, 2009 11:10 PM
S4poor
Aug 28, 2007 01:19 PM
