Whoops
Old 06-17-2015, 08:40 AM
drowssap's Avatar
from the dealer they need your Vin.
Old 06-17-2015, 12:39 PM
Rosslato's Avatar
Thanx!
Old 06-17-2015, 04:24 PM
Originally Posted by Rosslato
Where do you get the radio code? When I bought my Rover it was sitting for 4 yrs and I installed a new battery and did not have the the code issue, radio plays fine. Just wondering for down the road if i ever have the radio code issue. Thanks
Ugghh, it should come with the original docs (I'm fortunate I had my truck from new). The only way I know is getting the serial number off of the rear of the radio and taking it to the LR main stealership who, I believe, if they are half helpful can request the radio code from LR. If you disconnect or change your battery you will defo need that code (bearing in mind it's also the satnav). There is a 'dodge' when changing batteries where you connect an old 12v in parallel using jump leads then remove the existing battery but that doesn't help when working on the truck when you require zero 12V power everywhere.
