Why Didn't I Think of This?
I feel extra stupid now for all the times I burned my arm trying to find the source of that annoying exhaust tick: How to Diagnose Exhaust Leaks With a Shop-Vac | FCP Euro
Works fine on a diesel with no cat and a single exhaust. Get the wife to hold the rag over the exhaust (if she's a PITA don't give her leather work gloves) whilst you spray the joints with water + washing up liquid. Or alternatively, you hold the rag over the exhaust but wearing leather work gloves whilst she crawls underneath with the spray bottle ............... sounds good to me
The shop vac is better. No fumes and no hot manifolds, pipes or cats to burn you. Plus, how are you going to use soapy water on a hot exhaust? It will just vaporize as soon as it hits the pipes.
I have a leak in mine in the y-pipe just below the manifolds. I still have a slight tick when cold after having the manifolds ground flat and putting in all new gaskets so that's the only place left. I think I'll try this out to confirm it.
You are spot on right 04duxlr. I didn't consider the heat in the exhaust and unless you find the leak within a couple of minutes the liquid will evaporate on contact. (I'll go to the dunces step in the corner and wear the dunces hat )
