Why the heck would this hose look this way?
Old 08-18-2019, 01:19 PM
Brandon318's Avatar
Default Why the heck would this hose look this way?
Came outside to check the coolant levels before heading on a trip and noticed the top radiator coolant hose almost collapsed under vacuum. Opening the expansion tank relieved the pressure.
Old 08-19-2019, 02:44 AM
JUKE179r's Avatar
Air in the coolant system? bad coolant pressure cap? blockage in the smaller run off hose to the coolant reservoir?
OverRover (08-19-2019)
Old 08-19-2019, 07:55 AM
OverRover's Avatar
+1 and the fact you are using a garbage URO Parts hose!!!
UROParts, the mistake you only make once.
Discorama (08-21-2019)
Old 08-19-2019, 09:15 AM
DiscoBuckeye's Avatar
My experience with other vehicles that I have owned (I have never had this happen with my D2) It is typically the radiator cap or in our case the coolant overflow as mentioned already. I cant comment on the URO part because I have one too
Old 08-19-2019, 09:45 PM
Received 1,545 Likes on 1,268 Posts
URO = So bad even BritPart rejected it.
When I broke down on the road to Romp two years ago, the shop that fixed it up used World Pac to get the parts and while I was thankful they could get me back on the road with only 6 hours lost. The URO parts didn't last a year before they were garbage.
Old 08-20-2019, 04:42 PM
Brandon318's Avatar
Oh dang. Had no idea about URO struggles. I guess I get to replace hoses again.
Old 08-20-2019, 05:58 PM
Brandon318's Avatar
Just ordered all new LR hoses to replace the UROs. Noted for next time.
Old 08-20-2019, 06:33 PM
thom_77's Avatar
Can concur on the URO parts. They're notorious in the Mercedes/BMW community for disintegrating rubber components. If you're in a pinch and have no other option they'll get you home but definitely don't rely on them long-term.
Old 08-21-2019, 02:17 AM
JUKE179r's Avatar
Did you order a reservoir cap also?
Old 08-21-2019, 11:26 AM
Brandon318's Avatar
I did indeed. That was also URO. Such shame.
Quick Reply: Why the heck would this hose look this way?
