Will 265/60r18's Fit under my Disco II
I have 255/55r18's now and I want to go a bit larger. The 255/55's calculate to 29 inches on a online tire calculator but they actually measure to about 27 inches. The 265/60's calculate to 30.5 inches on a online calculator. Will the 265/65's fit ? I know they might rub a bit with articulation and tight cornering. Anyone that has this tire size please let me know about your experience. Thanks!
I have run them in the past with no problems. I assume you're running the stock 255/55 18s. The steering stops are a little longer on the discos with factory 18s so I didn't have any rubbing, or any other issues with them. Can't speak for that size on one that had factory 16s though. I'm currently running 255/60 18s. They're in between the 255/55s and the 265/60s size wise and tires in that size were considerably cheaper than the 255/55 and 265/60s so something to consider.
CalChrome
09-27-2013 12:25 PM
