Will 33" tires fit?
Old 03-20-2012 | 04:26 PM
srendon's Avatar
4th Gear
Thanks Mike. The lokers I'm looking at is the ARB air lockers. I'll see if I can cancel and send back the ones I've ordered. Thanks
Old 03-20-2012 | 04:28 PM
srendon's Avatar
4th Gear
Mike, what size lift is the OME? Thanks
Old 03-20-2012 | 05:02 PM
hilltoppersx's Avatar
you can also fit 33" tires with the Terrafirma 3" lift from Lucky 8. Again with a 3 inch lift and 33 inch tires you will need extended stainless steel brake lines or just good HD ones from a hydraulic shop.
Old 03-20-2012 | 05:03 PM
If you really want air lockers, go to Lucky 8 and look at the new Ashcroft lockers, Justin also has the 3 " Old Man Emu lift kits.
If you have any more questions, lets talk.
Old 03-20-2012 | 06:24 PM
ebg18t's Avatar
I have the TF 3" lift and 32.8" tires. It is a tight fit even with an aftermarket bumper. I would suggest stoking to a 32" tire to have some clearance. I will drop back down to a 275-65-18 for next my set. The 285-65-18's look good and provide a gret off road foot print. But can be a tight fit.
Also without the extra weight of steel bumpers & roofrack the TF 3" HD kit will ride a tad taught.
jycsalas
05-23-2019 03:02 PM
TRIARII
12-13-2013 02:09 AM
cmossman
07-19-2010 03:06 PM
Mtree
06-19-2009 08:46 AM
caustin
02-15-2009 04:14 PM
Quick Reply: Will 33" tires fit?
