will a Chevy block fit a Disco/ transmission
I am looking into a used 03 Disco with a blown motor, oil pump failure,
after doing some research on buying a used motor best i have found is about 2700.00 plus shipping about 300.00 the though occurred to me that if Rover used a Buick block , then wouldnt this then also be able to fit a Chevy block.
With all of the BS about replacing headgaskets at 70K and overheating problems due to cracked cylinders and all of the other assorted failure points.
Why cant this be a workable solution , I would appreciate your informed thoughts.
I know a cast iron block weighs more but since this is a truck it doesnt much matter if the reliability factor goes up.
Think about all of the failed RR vehicles that will never run again due to one of these failures or another, from the cast aluminum block and heads.
And poor customer that gets a bill for 10K for a new engine as the engine has 75K miles and has just chewed through a oil pump and taken out the block. This really is BS if you ask me, all i can say is .... WTF Rover
Note this isnt meant to start a flame war, I am looking at other possibilities. And seeking your thoughts, thanks......
There are adapter kits available that would allow you to drop in a GM 4.3L V6 into a Discovery. This is a very reasonable route to take, because the 4.3 is of similar weight, and makes similar power to the Rover 4.0. These are extremely durable engines. The GM 350 is not a very good swap, because they are way too heavy, and make more power than our drivetrains were designed to handle.
You can have a GM 4.3L and the adapter kit for FAR less than $2700 bucks.
I would think a bigger issue would be hooking up all of the electronics to the engine so the computers work correctly. Do you have he experience to know if you can address all of the sensors and electronics? I don't, but I have seen other guys drop motors of one brand into the chassis of another and spent an enormous amount of time getting the electronics hooked up and functioning correctly.
http://www.youtube.com/user/TimePilo.../8/UjPkLnULtCM
Here in Colorado you can get away with this. I have a 1993 350tbi engine in my 72 Land Cruiser, it passed envirotest with flying colors. In fact way under what a 72' should read. Little video fun.
I had a real nice 76FJ 40 sold it bought a 04 Disco and had to sell that to buy my house. Now i have a OK FJ 60 wagon but it just doesnt have the steam to go up the mountains, a V8 would be nice , but i would rather have another Disco as i liked the interior and seating position, The FJ 60 does go great in the snow with a thin set of Bridgstone Revos.
All of the Rovers with the bogus engine problems are really a disappointment.
Yeah are we as owners /mechanics able to fix them? in a word yes, but why should we have to, seriously telling an owner your trucks going to need head gaskets at 80K miles because they all do isnt a great thing.......anyone else feel this way.
How hard would it be to just install a iron block with aluminum heads and use the rest of the Rover parts to make it function??
Any one have any ideas?
Marks has them, $895 however. Then you have $600 for the engine and ECU, figure another $400 in exhaust parts. Then of course you need to be a pretty solid welded to install the motor mounts. Was easy on my 40' but I think the LR would be a challenge.
http://www.marks4wd.com/products/eng...6-V8.html#GMV8
