Will not turn over
Old Dec 27, 2008 | 08:28 PM
renow1963's Avatar
Default Will not turn over
My 1195 Disco...will not turn over..period...Recently replaced the battery, this after a record cold night here in Central Indiana...Also in the past week...prior to the truck not starting I had the entire exhaust repalced...everything from manifolds on back..
However withthe new battery installed..the interior lights come on, the wipers work, radio etc....the engine isn't turning over..nothing...the started was replaced about a year ago...any sugestions ???
Thank you in advance for your help....
Old Dec 27, 2008 | 08:34 PM
AK Rover's Avatar
Default RE: Will not turn over
Make sure it is completely in park. The radio will come on in the 1 position, when you turn the key to 2 do you get dash lights? If that doesn't work make sure your security system is disarmed. The security has a start disable that will cause that.
Old Dec 28, 2008 | 08:46 AM
You probably have a new battery with little or no charge in it, get it charged for 2 hours then reinstall and see what happens. If it still doesn't turn over get in touch with me.
murswan
Jan 26, 2022 12:27 PM
RoverJeep
Mar 26, 2020 03:10 AM
SolbergFanBoi
Mar 5, 2012 07:05 PM
RoverPhotog
May 9, 2010 02:40 PM
yukonridin23
Jan 25, 2010 02:47 AM
