Will these tires fit?
Old Jun 16, 2010 | 12:40 PM
molendast's Avatar
5th Gear
Default Will these tires fit?
I have an '04 SE Disco - no upgrades (yet). Currently all original equipment.
When I get some extra cash, I'm planning on a 2" lift along with sizing down to 16" steelies with some bigger tires. In the meantime, I want something to go on the 18" hurricanes that are better than what i've got. Since my current tires have just about no tread left on them, anything would be better.
That said, I found a lightly used set of Goodyear Wrangler AT/S tires (275/65/18), that I could pretty much steal, but i'm not sure if they'd cause any issues due to the different size (OE is 255/55/18). Thoughts?
Any feedback is appreciated.
Old Jun 16, 2010 | 04:24 PM
03discoman's Avatar
i bet they fit,,,might rub a lil...just adjust your steering stops a lil
Old Jun 16, 2010 | 04:40 PM
green machine's Avatar
Tire information here.
http://www.discoweb.org/
LR03NJ's Avatar
Got same tires but Duratrac's with 2"OME, No rubbing yet for 6k miles.
Old Jun 16, 2010 | 04:43 PM
[quote=green machine;182880]Tire information here.
Sorry the link didn't copy right and it wouldn't let me edit my original post...
Go to the tech section and click on tires & wheels
Old Jun 16, 2010 | 05:22 PM
How do you like your Dura Trac, from everything I have heard, they are hard to beat.
As for the original question, I wouldn't mount that size tire without a lift or you will be limited to flat level roads with no dips or you'll get into the metal.
Old Jun 16, 2010 | 06:09 PM
Camdisco24's Avatar
You'll rub a little bit with that size off road, on road you'll prob be fine.
I run 255/60/r18 and its about as big as I would go without a lift off road road.
VikingDiesel
May 26, 2009 02:43 PM
Camdisco24
Dec 18, 2008 04:33 PM
99LRDisc
Jul 18, 2008 10:46 PM
ccoder
Tires
Aug 28, 2007 08:56 AM
Disco.Jay
Feb 20, 2006 08:00 PM
