Winch = dual battery?
I am looking at the idea of adding a winch since I was offered one a very good price. But will I need a dual battery setup to handle the draw from the winch? I am running a diehard platinum battery (1200 cca) that is almost new. If I need to do a dual battery I am going to pass on the winch deal. Thoughts?
Many winch units need a 650 to 800 CCA battery, and there are guys who run just one battery. But consider all the electronics in the D2, and if you place a really heavy load on the electrical system and make the ECU or something else go crazy, a tough but fun situation could become a lot more difficult.
I am not sure I want my wench's to have a heavy drawl.
Which alternator are you looking at?
Any commonly available alternator is not going to keep up with a winch's draw (anywhere from 350-450 amps at stall). All it will do is make your battery last a little longer and recharge it sooner.
If you're just using the winch for occasional short pulls a single battery is fine. The longer the pull or the worse the stuck, the shorter the time the battery will last.
For comparison, I ran my Warn 8274 on a Land Rover in the 70's with a single deep cycle battery and a 60amp alternator.
on
Spending the money for a high out-put alternator is a waste of money.
The biggest issue with any electric motor is the lack of total amps required under load, yes, a bigger alternator can do that but so so can i serious battery like a Yellow Top or Sears Marine Platinum for normal pulls or duals when you are making 10 or more pulls in a row, then the electric motor gets hot as do the batterys and failures start to occur.
