Window ECU repair kit from AB
Old Dec 22, 2008 | 02:11 PM
hazletbassist89's Avatar
Default Window ECU repair kit from AB
Anyone tried it? I ordered it and I'm trying to install it now but I'm confused. I pulled the glove and attached the wire as specified to the ECU connector, but I can't find the wire it's talking about for the second part.
Here's the instructions:
http://www.roverparts.com/Instructio...tRepairKit.cfm
the part I'm talking about is step 4. I don't think I have a green and white wire in the connector. Unless I'm looking at the wrong one?
EDIT:I found it, I was looking at the wrong connector. Kit didn't work though, so I guess the next time is swapping some switches to see if I can get my rear windows to work again. [:@]
Old Dec 22, 2008 | 02:40 PM
Default RE: Window ECU repair kit from AB
Mitch,
The more common thing to fail, especially if you are talking about your rear windows is the body ECU, usually the board cracks or a soldier joint fails, both of which can be repaired.
I would open it up and see what you find.
twoxred
Oct 4, 2021 07:07 AM
RedAustinIX
Aug 10, 2020 11:43 PM
Paul Grant
Aug 10, 2014 12:29 PM
ajordan_0012000
Oct 16, 2008 06:44 PM
