Window Regulator 2000 Disco
Old Oct 16, 2008 | 01:34 PM
Rich 00 DISCO's Avatar
Default Window Regulator 2000 Disco
Reasonably mechanical newbiereplacing regulator right front. Will buy part from Roverland. Anyone have step by step instructions?Does this require calibration?Any special tooling?
Worried about correct microswitch placement, if applicable.
Window went down quietly, never went up - motor still runs.
Irecently replaced the lock actuator without trouble (without pulling out window - just removed bolts top and bottom rear window guide, soI already know my way around thebasics.Thanks in advance.
Old Oct 16, 2008 | 05:00 PM
Default RE: Window Regulator 2000 Disco
If you can replace the lock actuator then you can replace the window regulator.
There is a write up on it, it was a couple of days ago. A guy fixed his regulator with parts from the HomeDepot for like $5.
Just start going back page by page and read the title of the posts until you find it.
Sorry I cant be more helpful.
Old Oct 17, 2008 | 07:17 AM
Thanks, Spike. Will do.
Old Oct 17, 2008 | 09:25 AM
2000 Disco 2 SD7's Avatar
Rich,
If you have the RAVE cd, you will finddwgs. and step-by-step R&R instructions.
Old Oct 17, 2008 | 11:11 PM
tacomatech's Avatar
Remove door panel. Wind window down to access bolts holding glass to regulator. Unbolt regulator. Pull glass to top of door and use tape or suction cups to hold up. Disconnect motor connector. remove the 6-8mm bolts holding regulator to door. Remove regulator and motor assembly. Reverse removal procedure. No calibration required.
Old Oct 20, 2008 | 12:43 PM
Thanks Tacomatech & all - that's what I needed. I'm going to go with a new unit as I can get it for around $175.I need to get that Rave CD for the next few so that I don't contribute to the clutter already here.
Old Oct 20, 2008 | 10:44 PM
tacomatech's Avatar
Same basic procedure for all other doors.
RedAustinIX
Aug 10, 2020 11:43 PM
K6EDA
Oct 23, 2011 09:01 PM
Al Blue4.6l
Aug 14, 2011 05:28 PM
phillman98
Dec 4, 2010 10:01 PM
jw928
Feb 6, 2010 06:51 PM
