Window stopped while down
RE: Window stopped while down
No, if you take the inside off the door you can check the regulator to see if it is good or not, the window ECU can get a crack in the circuit board and then the widow(s) wont work. If you can find the crack and then re-solder it it will work again.
On a DI the window ECU is located behind the glove box, not sure about a DII.
tsuyoi
09-22-2020 10:37 AM
Jared9220
01-28-2013 08:23 AM
